rmartin930
- Joined
- Jan 14, 2008
- Messages
- 18
Hi,
I have two bay 60 hoods, one for my 80mm CFE and one for my 150mm CFi, and both are "cut" so--when locked into place--they line up with the "Hasselblad" logo top dead center (tdc). The cuts in the bayonet ring are aligned such that there's one perfectly centered at the position of the "Hasselblad" logo.
I just bought a bay 70 for my 50mm CFi FLE, and its cuts are offset; so, with the "Hasselblad" logo tdc, the square hood is off by about 40 degrees. To "align" the hood, where a flat side is tdc, the "Hasselblad" logo winds up being turned 90 degrees. (Hope all this makes sense!)
Now, I realize none of this has any direct bearing on the viability of the hood to do its job, but I'm wondering if I happened to receive a defective hood or if this is normal.
Can anyone speak to this?
Thanks,
Rob
Thanks,
Rob
