what cards are you guys using
O.K. guys thanks for the hints.
I have done some googling and found the main differences between the
SAN DISK EXTREME IV and the EXTREME DUCATI EDITION .
The EXTREME IV CF card has a speed rating of 38.1MB/sec
and the EXTREME DUCATI CF card a speed rating of 42.9MB/sec + an improved controller firmware .
Prices for both CF cards look very much the same (at the moment) .
i saw a web site which i can not remember where a guy test the real speed of each card for a camera model...of course hassy is not on the list ..but for the canon 1ds mark there cards claming 38+/sec rate were actually doing like 16.2 /sec.. crazy ha..i will try to find that site..
lemon
I'm using a Sandisk 32 gig in my H3D-II/31.
Write speed and buffer of the camera is the determining factor not just the card. Where a faster card like the Sandisk Ducati is realized is in the transfer speed to the computer.
When shooting rapidly and a lot of images, I use the Hasselblad Image Bank-II. This dedicated drive has no burst limit and records as fast as you shoot for as long as you shoot. It saves images without any buffer stall what-so-ever. 2,280 image can be captured with my H3D-II/31 ... 1880 with the H3D-II/39. Downloads to the computer are also swift because this is a FW800 device.
Yes Marc , you are right . The given speed rating is the rating for the data transfer from the card to the computer .
Therefore , I do not see a need to buy a DUCATI CF card because the EXTREME IV CF card is just fast enough for my purpose.
And i have that Card Reader which is is Damn rocket fast to write to computer, i can transfer 12gb full to my computer in few minutes [about 6-9minutes]
Yeah, but DUCATI sounds cools and they are really fancy and pretty looking. If you are going to buy the camera, why skimp on everyday ordinary looking disks? Seriously, I also don't see much performance improvement over the Sandisk Extreme IV, but then again, I don't shoot off with my Hasselblad camera as I may with a P&S.
Regards
David
David
Yes , it sounds cool , as cool as CHATEAU LAFITTE ROTHSHILD 1969 .:z04_bier01: .......Rothschild!
David
I bought a bottle of that during my first trip to Paris. 10 years later, I squandered it at a dinner party, and only ended up with a small glass of it.
A fool and his 1969 Rothschild are soon parted.
I think it may actually be safer to use, say 2 cards of 4 GB, than one of 8 or more GB just in case something goes wrong.
I have to disagee on using smaller cards. The file sizes from these cameras fill up small cards at a ferocious rate.
In all of the research I've read, the vast majority of so called card faliures are due to user error, reader malfunctions, misplaced cards, over-shot cards, etc. rather than actual card failure.
The more cards you are pulling in and out of the camera and the reader the more likely there will be a user error or misplaced card in the heat of shooting.
I use 32 gigs in the H3D so I never have to take the card out, or worry much if I'm nearing the end of the capacity ... which frequently causes a currupt file.
Just an opinion based on shooting these camera a lot for paying jobs.
while that may be true if one does leave the cards in the back, mileage may indeed vary if one uses an external reader. I am always using cards with an external reader. All these manipulations may indeed render things a bit less stable.
guess what..i went started looking for that data bank...guess its not compatible witht the 50mp ..
i was having a stupid silly thought...50mp ...50-100 lense plust the honking sony battery in the bottom and the data bank.......wowsers..
hahahhahaha..about a light bowling bowl..
Lemon
Is it true that the 50 can't use the Image Bank II? Anything in the pipeline to address this?
This is from the R339 firmware readme dated July 20, 2009 available at www.hasselblad.com
It does work and I have tested it.
Hasselblad A/S
July 20, 2009
Firmware version R339
This package contains firmware version R339.CIM for the H3DII-50 sensor unit.
Version R339 is a feature and bugfix release of version R332.
Changes since version R332:
- Improved tethered capture performance (Up to 75% on fast computers)
- ISO800 support
- ImageBank-II support
- Shorter start-up time
- Improved power handling
- Added new CF-card types
- Added H3DII-50MS support
- Improved hardware previews
- Improved firewire stability
Paul Claesson
Hasselblad USA
i´m using sandisk ultra II for my Phase One P30 Back on my H System. never had any performance issues.
joe
