cs_foto
Hi guys, I'm a bit new to the hasselblad world. i own a 500 c/m,
in the beginnings i used to shoot mostly using a tripod..
recently i used the hassy hand-held for the first time, shot about 4 rolls with it.. what i noticed after processing is that most of the shots are blurred, blurred as in camera shake.. i shooted mostly at 1/60th and 1/125th of a second, with the 80mm lens..
I was wondering what do you guys suggest from experience as the minimun speed to use hand held, normally on 35mm film i go as slow as 1/60th without problem on a 50mm lens.. so i guessed i could use the same speed.. but it seems i was wrong...
also what are your thoughts on mirror flip, for me it seems it shakes the camera a lot, also what about the proper grip? or cable releases? would be nice to hear from someone who had used this camera a lot hand-held...
ideas?
thanks a lot
ideas?
thanks a lot
