Q.G.
The FLEXBODY obviously came with screen adapter 72405 and the above given correction slides + some other parts .
I have bought screen adapter 41057 some years ago , and got the three slides (see above on page 1) with it in a little black leather pouch . I never used the coorection slides , as i have no FLEXBODY . But now as i can attach HASSELBLAD magazines to my ARCASWISS 6x9 , i will have to use them .
The technical setup is as follows .
The lens is APO-GRANDAGON 5,6/45mm (as for the ARC-BODY , but without focus mount) .
When using the SWC screen adapter (41050) , i get a very bright and clear image on screen , but when doing a shift more then 5 mm , i get a very distorted image on screen .
Now , using the adapter 41057 with the correction slide 10* , i can shift to about 15 mm and with the correction slide 20* up to 25mm getting a clear image on screen , when inserting the correction slide with the 10* , 20* label showing away from me (towards the lens) .
When i insert the correction slides with the 10* , 20* label showing to me , i get extremely distorted images with the background doubled on screen .
I have no description , on how to use the slides and also cant get one . HASSELBLAD Germany told me , the slides have to be used with the label showing towards the photographer , but that gives me , as described above , obviously the wrong results .
Can you and might be other users of the FLEXBODY (or ARCBODY) help ? ?
