I'm sitting in my kitchen with an old Hasselblad catalogue from seems to be about 1998 - back when the 501cm and 503cw were made in tandem with the 555eld, 203fe and 205fcc. In the last few days I passed on a beautiful 500cm kit because I decided I really needed to do my homework and see what the differences between all the V series are before spending my money. It seems now that the only V series camera still in production is the 503cw. It's a real bummer!
Anyway, from my reading it seems that the 501cm is perhaps the best bet for me. They came standard with bright screen, it has the (I think) GMS like the 503, just doesn't have a few minor things I'd never use.
My question for other forum members follow:
1: Is the 501cm easier to get serviced than a standard 500cm? ie, are parts still relatively easy to replace through Hasselblad service centers? How do the two cameras compare in this regard?
2: Does the GMS make a big difference? I understand that it only matters with lenses longer than 100mm. I'm usually a 50mm and 80mm man but would buy a blad kit to get into more macro work that I can't do on my rangefinder cameras.
3:I don't think that I could ever afford it, but are the 501cm and 500cm just as useable with a digi back? Do you have to connect a cord between the flash pc socket to the digi back on both cameras? How does this compare to the 503cw?
4: What's the difference between the differenct lenses? CF, CFE etc?
5: Is the V series being killed off? Reading other posts here it seems there is a lot of animosity towards Hasselblad for not developing new lines of backs and accessories compared to the H system. I'm committed to film at this stage but I would be nice to think if I sink a lot of money into a V system I can move with the times when / if I need to.
Thanks for your help.
Tim
Tim
