Hi,
after buying my first hassy, i did the following test.
I put a newspaper under 45 degrees, in the middle draw a line. I put the camera on a tripod horizontally focussed at the drawn line. camera was balanced, middle of the lens at the height of the line.
I shot a picture with the 80 at 2.8. Distance was +/- 0.95meter. So almost at the most near position of this lens as possible.
I focussed at the line.
The result gave a image where most sharp area was not the line but behind it. The line was at the edge.
I did the same test with the 150mm lens, same result. I checked my eyes, looked through a loup at the groundglass, and al looked fine...
Is it possible that these lenses are not at there best for closeup work at almost the minimum range of 0.9 meter this lens is capable of? Is this by design?
