Loose tube on the 50mm CM lens
  • Thread starter Thread starter 4nicholas
  • Start date Start date
4
4nicholas
Hi again, one more question... I have a 50mm T*CM lens. The exterior main conical tube is loose and i have shaken out two ss screw. is there a way I can replace these two screws without taking apart the whole lens? I am pretty handy, but if this is a job for a lens tech, i'll send it off. ( i love this lens) i just thought it might be a relatively easy fix. THANKS!
Nicholas,
It is possible for you to replace these screws yourself. Here's what you need to do:
First, you will need to remove the black, round ring that has the serial number on it. This can be removed by using a friction wrench. This "wrench" is a round, black rubber tool, which looks like a large rubber cork. You simply press the wrench on the ring, and turn it counter-clockwise. This wrench can be purchased from companies that sell camera repair tools. Or, you can make one yourself. Go to your local hardware store. They sell rubber stoppers in different sizes. Purchase one that is the same size as the ring. You will have to remove some of the rubber in the center of the stopper, due to the curve of the front lens. Once you remove enough of the rubber so that the outer part of the stopper sits flat on the ring, turn the stopper counter-clockwise, and the ring will come off.
Then you will need to remove the front element. This can be done using a spanner wrench.
Once the front element has been removed, you will see 3 holes in the front tube. The 3 screws thread into these holes to hold the front tube on.
Once you replace the screws, you simply put the front element in, and then reinstall the black ring.
David S. Odess
28 South Main Street #104
Randolph, MA 02368
(781) 963-1166
David, thank you so much for your help on this! i will give it a shot! you have saved me so much time as my tech shop is 400 miles away. i really appreciate it!
nicholas
