Just received a 50mm F/4 Distagon C T* and a 150mm F/4 Sonnar C T*
I received both from the one gentleman for far less than the going rate for a 150mm F/4 CF lens, so got a bit of a bargain. Both had been recently serviced and I received the reports for both lenses, both being in great condition (though cosmetically the lens barrels show obvious signs of use for lenses of this vintage).
The 50mm Shutter Speed test showed that the shutter speeds are slightly up and down across the board though still within acceptable tolerance. I think I may put this in for a service / repair later in the year though as I imagine it will get the most use as a wide walk-around lens.
Can anyone recommend a good, certified repair / service person in the Sydney CBD? Also, what should my service schedule be for these old lenses considering they will received fair to moderate use?
I may also be putting my 80mm Planar in for repair as it does not stay cocked when it is removed from the body, though the two C lenses perform fine in this respect (ruling out a body issue).
Thanks in advance!
Thanks in advance!
