Hello All!
As this is a somewhat general question about "film to digital" darkrooms, I thought it may be worth its own thread.
I'm wondering if anyone has a similar setup, or similar experiences, especially about profiling of the scanner, the CRT/LCD, and the printer, and the printed results, in a film to digital 'lightroom'. Perhaps we can share some notes in this forum.
I am a digital darkroom novice, so in theory at least, I'm sure I'm making a lot of 'greenhorn' errors.
BACKGROUND: My 'lightroom' major players are:
Epson V750M Flatbed SCANNER with Silverfast, Apple 24" iMac Intel 2.33GHz Core 2 Duo COMPUTER OS X 10.4.8, 2GB SDRAM, and an Epson R2400 PRINTER. Also a 500GB HD external, etc.
I am really happy with my hardware.
The software is PS CS2, with Bridge, Aperture, or Lightzone available. As early as this is in my learning curve, I am not fully 'into' the Bridge, Aperture or Lightzone (although LZ is very intriguing...)
I still shoot film for my 'real' fine art work - either Fuji chromes or Ilford Delta 100 Pro. (I do use a Leica for RAW digital at times, but I am more interested in the entire workflow from pos/neg to print.) My scanned files are enormous, but I have the computer firepower to handle it.
FIRST QUESTION: Am I on the right track with Profiles.
I use the latest Epson profiles for the scanner. I profile/calibrate the LCD with my Macbeth Eye-One D2. And as I have only used various Epson papers so far, I use Epson downloaded .icc printer profiles.
SECOND QUESTION: When I calibrate the LCD (weekly), it gives me a (current dated) 'profile'. When I scan using Silverfast 6Ai inside the PS CS2, the scanned file is in the LCD's 'dated' profile, but not the 'working space' (which I use as RGB). Am I supposed to change the file to the 'working space' at this first 'save' opportunity? If I do, do I lose the LCD profile 'correct viewing'? Do I work all through my Levels, Adjustments, Crop etc, and then finally go to RGB? Or what? I seem to have the color-management print instructions working OK.
That's enough to start a thread, perhaps. I might add that I have been getting some pretty good (beginner's luck) results by trial and error, up to 12x12 and 12x16, using 13x19 paper (Epson Gloss and Semi Gloss). I did a 10 picture portolio B&W exhibition in December in 18x24 frames which went OK.
I am just not getting the CONSISTENCY I want - which I need before I invest in Hahnemuhle William Turner papers, or similar.)
I look forward to some forum correspondence !
Cheers,
Colin
Cheers,
Colin
