stewart_skelt
- Joined
- Jan 14, 2008
- Messages
- 14
I have a 50mm C lens (T*, but I don't suppose that is relevant). The main housing of the barrel has become slightly loose, in that there is 1-2 degrees of play, rotating around the central axis. There is no play lengthwise, so there does not currently seem to be a risk of the lens elements getting further apart than they should be. I have checked and none of the visible screws is loose.
Two questions:
1. Do I need to worry?
2. If the answer is "yes", is there anything I can do myself? I am not afraid to use a lens spanner and screwdrivers...
thanks
Two questions:
thanks
