franloutwo
The lens has slight movemnt in the barrel I would characterize it as extremely slight. The lens has been used with good results, however, the issue of the barrel movement is driving me slightly nuts. Please note as stated to date the lens has perforemed as it should. Would you be concerned about the movement in the barrel and send to Hasselblad for an overhaul or just keep using and not concern myself with this issue.
