simonpg
Pardon my ignorance here, but I have an opportunity coming up soon to shoot (as in photograph) some models in a studio. It will be set up with a range of strobe/flash heads and other mods and cons.
So I am wondering if I can shoot in this environment using the TTL flash feature of my 503CW - if I can, is it worth doing of not?
Currently I have a Metz 45CL-4 with the full SCA TTL connectors for my 503CW; I also have the D40. I do not plan to use either unit in this shoot because of the studio lighting set up.
So, my question is: can I achieve TTL flash with some other connector (like a cable with a big jack type plug that connects to the main flash head (slaves on the others); a sync plug to the lens sync port; a din multi pin plug to the camera body) if such a beast exists? Is it worth doing - I am suspecting not?!
Is it feasible for me to connect say the D40 and have slaves on the studio flash heads to trigger them (and only aim the D40 at a slave unit and not the subject area) - will the 503CW TTL successfully work out the lighting?
I once remember being told that with my EOS 1vHS and its ETTL flash control in a studio multi- flash/strobe setting, manual camera settings based on one light-meter reading is better as the camera will be confused by all the flashes going off together - fact or fiction? The EOS ETTL is a multi-flash capable system so I am not convinced it would be so confused. Would the 503CW TTL flash control be so confused (there will be 3-4 units)?
Am I just better to use the 503 in a fully manual mode based on good flash light readings from my Sekonic and simply only plug the lens sync port alone to the flash/strobe system?
Apologies for the big story, but I am not studio flash experienced and I'm keen to take this opportunity to give it a try and learn. Thanks.
