BlueLemon
I just jammed my 503CW with Winder.
I mounted extension ring 21 with a C version 60mm Distagon.
When i tried to exposure, the mirror went halfway up and jammed.... The winder tried continously to forward to bring the mirror all the way up - but its just stuck.
I previously have tried to unlock a 501cm succesfully..... but this problem I cannot.
The reason is both the the winder cannot be un-mounted because
1) 21 mm extensionring is in the way to unmount winder
2) The screw in the mirrorchamper is firmly stuck
Does any have any solution to this ? Is the 21 extension ring not compatible with the 503CW ??? hmmm
Well any help appreciated.....
Damn - you should never fool with you equipment on saturdays
Claus Stensgaard
Claus Stensgaard
