Wider spectrum....
You forgot the Schott filters for UV applications.
Not particularly low cost like Wratten 87 filters but very very good.
Vic.
Vic.
Oh, Schott have IR filters as well :) And much more durable in what is most likely the best optical glass in the world. I did not really forget them, it is
just I cannot memorise their filter designations as easily.
For the curious, Schott have a comprehensive overview here
Anyone tried the Phase One Achromatic out yet?
Just wanted to see if it also could do that...
UV-shot
or that
UV-VIS differential
Just kiddin - of course not, as it is only a monochrome back ... ;)
The "normal" VIS image btw is that one:
Klaus
uvir.eu
Thanks, I hope they still are ... ;)
To make things clear, you don't have to have a UV-Sonnar
to be able to make those - it helps and it is a bit easier,
but there are also other possibilities.
More about that on my BLOG uvir.eu
Cheers, Klaus
Spring Daffodils meet ZEISS UV-Sonnar 105mm
Zeiss UV-Sonnar 105mm, Hasselblad 501 C/M body, Phase One digiback
[that "black" background cardboard I was using was not black in UV]
Not much to see in UV except the lit tips on the petals and the structure
on that petal surface which gets visible.
