UNCOMMON LENS?? Hasselblad HC 50mm f:4?
john_l
Hello everyone,
And thanks in advance for any help you can give in this matter. A fellow pro and friend of mine looking for a second hand Hasselblad HC 50mm f:3,5 stumbled across a lens that appears identical but is marked on the front of the lens as featuring an f:4 aperture instead of 3,5. Never heard of that one, and what's more the dealer is offering it 500Euros cheaper. I would guess it must be a first version or japan only version (i am thinking of some fujinon lenses that were meant to be for asian market only??) so an "older" lens hence the much lower asking price. My friend did not ask for the number of shutter actuations so that is an element I am not aware of. By the way how many can a HC lens shutter go through before having parts (i.e. : main spring) needing to be replaced?
Thanks again and look forward to a reply on this one.
Is this one for Hasselblad only to answer?? It would appear to be the case...quite a few people read this post and none seem to be able to give an aswer...:uhoh:
Yes, I would inquire through Hasselblad. The caution would be to make sure the lens will actually work on your friend's H camera ... the lens firmware may not be compatible. Some earlier HC lenses for the H1 needed the lens firmware updated at Hasselblad to work on the H2 and H3D.
-Marc
