PC problem with Phocus
jlm
i cannot get Phocus 1.2 or 1.2.1 for PC to run on my main xp computer.
also had to load a couple of windows net things
it loads and says successful install, but the program hangs when started, showing the banner and main screen. have to alt-ctrl-delete to end it. tried disconnecting all external drives and card readers, no joy
been in many conversations with hassy tech, even tried a new beta version, as well as the CD version.
the PC version does run on my PC laptop, also the mac version on my MBpro
at one point six months ago, i replaced my C: drive for a larger one, but all has been working fine until the Phocus fiasco
thanks
Jim
I am glad you've been in touch with Hasselblad support.
It is difficult for me to even make an educated guess at what is taking place without any specs about the computer or age of the computer.
My first thoughts: Not enough memory or the video card is not adequate.
computer is a dell 380 workstation, Pentium D 2.8Ghz, 4Gb ram
XP pro version 2002, sp3
Nvidia Quadro FX 3450/4000 SDI
I'm bringing in a tech to look over my system
tahaks for the reply.
so far the CFV39 is looking pretty good
thanks Paul
please recommend a suitable new graphics adapter. i run two monitors: dell 30" and Eizo CG24
thanks
thanks Paul
thanks
Running two monitors is an important bit of information.
I suggest running two graphics cards, one for reach monitor.
From the readme file:
Graphics card
At least 256MB of video RAM is required. Unlike older graphics applications such as Photoshop and FlexColor, Phocus utilizes the processing power available in the graphics card to provide precise real time feedback for adjustment changes. Therefore, just as with Aperture, the viewer performance is very much dependent on the quality of the graphics adapter. In general, more video RAM is better, especially if you plan to work with 30” displays or dual monitor setups. Not all graphic adapters are supported! As a
minimum Direct X 9.0c compatible graphic adapters are required, yet not all are guaranteed to work.
The following is a list of graphic adapters that meets the requirements:
NVIDIA: ATI: Intel:
Quadro series Radeon HD 4800 Series GMA 3500 (limitations apply)
GeForce 9 series Radeon HD 3000 Series GMA 3100 (limitations apply)
GeForce 8 series Radeon HD 2000 Series
GeForce 7 series Radeon X 1000 Series
GeForce 6
  • EXIF
    Phocus_PC_1.2.1_readme.pdf
  • EXIF
since i already have the quadro, and it is approved, do i assume having only 256M of video ram is too punky for my twin monitor setup? should i just get another identical GC, or a better one with mor video ram?
jm
after a quick check, i am finding GC priced from 50$ t0 $4000. a few list directx10 compatible
like this:
BFG BFGEGTX2851024OCBE Geforce GTX 285 1GB GDDR3 PCIE Video Card
1GB GDRR3 SDRAM / PCI Express 2.0 x 16 / 2560 x 1600 resolution / SLI supported / Dual-Link DVI / NVIDIA CUDA Technology / DirectX 10 [ BFG X2851024OCB ]
not clear if it is a 9 series, but it has 1G video ram and can run two monitors
or this:
XFX HD-489A-ZDFC Radeon HD 4890 1GB DDR5 PCIE Video Card
1GB DDR5 SDRAM / PCI Express 2.0 / 2560 x 1600 resolution / Dual DVI / Quad mode CrossFireX supports / ATI Avivo HD / Blu-ray & HD support [ XFX HD489AZDFC ]
not clear if it is directx9
Jim,
I posted a portion of the Phocus Readme file i.e. Graphic cards as a reference.
Checking a manufacturers Readme is always a good place to start. Generally it will tell of improvements, functionality changes, bug issues, known issues etc.
When Quadro is mentioned in the Readme is refers to the Quadro Family of Graphic cards. The number of graphic cards is in the hundreds manufactured by many vendors. Therefore is very hard for me to isolate one card and states this is what you need.
I would suggest looking for a card that has a minimum of 512mb Vram, 1gb would be great and yield a significent improvement on performance. You have to weight the options between cost and performance, the more you pay the better the performance.
My speciality is Hasselblad hardware: V, H and X cameras, digital systems and software unfortuneatly it is not GC.
The information for Graphic cards from Nvidia can be found below, you may wish to contact them.
http://www.nvidia.com/content/HelpMeChoose/fx2/HelpMeChoose.asp?lang=en-us
http://www.nvidia.com/page/contact_information.html
NVIDIA CORPORATE OFFICE:
2701 San Tomas Expressway
Santa Clara, CA 95050
Tel: 408-486-2000
I hope this helps.
Paul Claesson
Hasselblad USA
thanks paul.
I did call Nvidia and found that most of the cards listed as compatible are discontinued.
I ended up with the Quadro FX 1800, 760 Mb vram, about $450
just got it and will be installing this afternoon.
installed the new board...BINGO, all is working. both monitors, Phocus, etc.
yippee, this weekend i can get productive!
i am up and running but have a few problems:
1. i do not have a "scratchpad" folder on my desktop. consequently, imported files get dumped on the desktop directly.
2. If i try to select a custom location when importing files by editing the location bar in the Import drop down menu, it shows the new location, but then keeps dumping the files on my desktop. the text on the Import drop down box is very slightly clipped at the bottom of each row of text.
3. I cannot click on the Adjustments text on the toolbar, that text isa lso slightly clipped on the bottom, therefore I cannot get to the Adjustments Browser
can sharpening, and other adjusments be turned off by un-clicking the green check mark in the box next to that tool?. i typically like to apply sharpening at the last stage of print prep in CS4
thanks
JIm
Are using and commenting on 1.2.1 version of Phocus?
Phocus manual version 5, page 14.
List of files
Capture Destination: Contains the folders that store imported or saved
captures.
When Phocus is launched for the first time, a Scratchpad folder is automatically created and appears on the Desktop, by default. This folder becomes the automatic destination folder for all captures whether they are imported from a CF-card, ImageBank-II or directly from a tethered camera, until you choose otherwise.
In Phocus, you can access the Scratchpad in the File Browser panel under the Capture Destination heading. Clicking on the Scratchpad icon will cause the contents to appear in the Thumbnail Browser.
Other folders can be created or chosen as destination folders instead of the Scratchpad as follows:
1. Create a new folder and name it.
2. Choose the File Browser and navigate down through the menu to the new
folder.
3. Ctrl click / Right click it to display the pop up menu where you can select
‘Use as Capture Destination’.
I suggest creating a new folder on you desktop and drag all the 3f files into that folder.
OPen Import dialog. The top line is Destination > Choose (to choose a existing location or you can create a new folder and this can be your destination for incoming 3f files.
3. I cannot click on the Adjustments text on the toolbar, that text isa lso slightly clipped on the bottom, therefore I cannot get to the Adjustments Browser can sharpening, and other adjusments be turned off by un-clicking the green check mark in the box next to that tool?. i typically like to apply sharpening at the last stage of print prep in CS4
I not sure i am following you. Are you talking about the adjustment Palette in the Adjustments tab? IF so can you resize the Phocus window in order to see all tools on right.
or are you talking about the title bar at top?
If you are in the US it may be easier to call me vs. waiting days for me to check the forums. my number is 973-227-7320 x209 or email at pclaesson@hasselbladusa.com
Who did you purchase the camera from?
Did they offer any training on the H3DII50 or Phocus software?
Paul Claesson
Hasselblad USA
finally got some time to get back to this.
first problem:
I created a sub-folder (Imports)into which to place my imports. in the Phocus browser, rt-clk the folder and set it as capture destination. It appears at the top of the browser list as capture destination.
Open the folder containing the 3FR files: my intention is to select all or many, then select Import and they should go the the capture destination, ("Imports").
what happens:
i select the 3fr files, then import. When I do select Import to , duh, import a selected file, a drop down menu appears, showing my desktop as the Destination, (even though the browser shows my "Imports" sub-folder as capture destination). If I then Edit the destination, (third line down, not the top line) selecting my "Imports sub-folder as the destination, the files still go to my desktop.
manually. i transfer the .fff files from my desktop to the "Imports" sub-folder. Now, back in the browser, if I click on the capture destination, showing "Imports" the fff files show up in the viewer, so it is seeing the same folder I am using.
second problem:
I do not get RGB readings when placing the pointer on the image, only jumpy readings, never over 7 or 8 and not for all three colors
my edition is 1.2.1 for the PC
also:
I process files into tiff files, but would like to use the proRGB color space. how do I choose that option?. currently I am getting aRGB from the processing and convert that when importing into CS4
thanks
