I have a few questions about Hasselblad even though I've been a user since 1974 I have little knowledge of various camera model numbers.
1. Which is preferable, the 203FE or the 205TCC ? I think there is some difference in metering but that is all I know.
2. Will the 503CW winder work on the 203FE?
3. The H lenses have a different mount than the "C/CF" lenses?
4. The 203FE requires FE lenses (and can use CF)?
5. Is there a 28mm or 30mm in the FE series lenses or is a 40mm still the widest?
6. I've seen references to a 212 body -- any info or is it a mistake?
There are NO Hasselblad dealers around here to ask -- no equipment to be found.
Thanks in advance.
BC
Thanks in advance.
BC
