what you would use Delay/Mirror Up for.
-Marc
Hi Peter.
Well, the option to set the wheel direction is one I wish I had on my Leica S2. Drives me nuts. It is the opposite of the H4D.
I think it all depends on what other cameras you use or have used, and having the ability to match the direction for the sake of quick intuitive "Muscle Memory".
-Marc
This one had me puzzled too. I guess if you had set a long self-timer, the available light kept changing, and you wanted the camera to keep adjusting exposure right up to the shutter firing. Otherwise, as soon as the mirror swings up, the exposure meter is blind.
Can't imagine that I'd ever use it.
There are a few options in the H system that I wonder who would ever use them. Must have been someone who thought it was a good idea.
Like custom option 8, to turn the control wheels to the opposite direction. Why?
Or the bracketing settings: where you can select standard, over, under, in every which way. Why?
Just because they could?
When Hasselblad created, designed and manufactured the original H1 camera in 2002, the thought was to include as many custom options to may be beneficial to photographers, they are options after all and the photographer can choose to use the default options and many did.
Finally, yes sometimes Hasselblad will implement a custom option or feature because we can....
Paul Claesson
Hasselblad Bron Inc.
Technical Support Manager
What might be nice is a "profile management" tool in Phocus. So that, on one screen, you can see all the options and exposure / focus settings and with a few clicks of a mouse, set up and save a new profile, uploading it to the camera. It'd make it easier to get your head around profiles. The Phocus "profile management" screen could also explain all the options in a bit more detail than the manual. The manual is great (compare it to the sparse 205 manual), but a bit more "why" could be helpful.
regards
Peter
