Doug, thanks for the response.
Can you add some practical tips on technique - quite literally a walk through of how you would incident meter a landscape vista?
LouisB
Sure, no problem.
The idea of incident light metering is to measure the intensity of the light falling on the subject. Most light meters, including the L-758, have a translucent dome or cone that can be positioned over the receptor for incident measurement. On the Gossen Digisix I use these days it is a little dome that slides into place.
When photographing a subject illuminated by a nearby light source an incident light measurement is made with the meter at the subject location and aimed at the camera location. The measurement has to be made at the subject location because the intensity of the illumination depends on the distance from the light source. If you cannot locate the meter at the subject location then incident measurement is not practical. An example would be actors or musicians on a stage. Fortunately, with a landscape things are easier.
With a landscape, or any other subject illuminated by the sun, the light source is at infinity so there is no need to locate the meter at the subject. Imagine a line from the center of the scene you want to photograph to the camera location. The meter can be located anywhere that has the same kind of light as the subject - direct sunlight, cloud cover, shade, etc. So long as the meter is held parallel to the imaginary line described above and pointed in the subject-to-camera direction it will read exactly as if it was at the subject location.
And finally, a practical example. Last summer I wanted to photograph a wooded hillside across a small lake from our campsite. A reflected light reading would have been thrown off by the specular highlights of the sun reflecting off the waves in the lake. I knew I could deal with them in post processing. It was the foliage across the lake I wanted to render accurately. The subject hillside was in open sunlight. I moved myself - and the camera on its tripod - so that I was also in open sunlight, turned to face directly away from the subject hillside, took just one incident reading, turned back towards the subject and took just one shot. That photo is now on the cover of the camp's new brochure for this year.
An interesting bit of trivia is that an incident light reading will be exactly the same as a reflected light reading of a standard 18% reflectance gray card held at the subject location.
--Doug
