jotloob
Well-Known Member
- Joined
- Mar 28, 2003
- Messages
- 1,946
I recently stumbled over an issue with my little LUMIX G1 looking at the images at 400% magnification in PSCS3/4 .
In the top and lower corner of the right part of the image , and only there , I discoverd a maze pattern , when the RAW file was converted either using LR2.4 or ACR5.4 . SILKYPIX , which comes with the G1 does not show this issue .
So far a short background . I have reported the issue in the ADOBE forum .
Today , I have inspected some files taken with my CFV and the RODENSTOCK 4,5/35mm DIGITAL lens .
(the wider the angle of the lens , the better the issue can be seen) .
They show the same maze pattern , when converting the 3FR RAW using either ACR or LR .
The maze pattern is not seen , when using PHOCUS .
This smells very much like an algorithm issue in the ADOBE software .
SO, why this thread here ? ? ?
Easy .
I would like to ask those of you , who use HASSELBLAD digital cameras or backs , to check if you get the same maze pattern .
If you are willing for a check , simply do the following .
Best you just shoot an image of a blue or grey sky . (widest angle lens you have) .
Convert that image to a TIFF file , using PHOCUS and also ACR or LR .
Save the files and open them using PSCS .
Inspect the right top and bottom corner at a magnification of 300% or higher .
For those of you who have to enlarge their images very much , this might turn out to be a severe issue .
I will supply a maze pattern later .
Easy .
