Jackaubrey
- Joined
- Feb 19, 2009
- Messages
- 40
Hi,
I recently purchased a 60mm Polarising filter but the bayonet fitting on the filter is very loose and it does not lock on properly to the lens.
On the Polarising filter the 3 filter lugs of the filter are 'flexible', i.e. only fixed at one end to provide the required tension to hold the filter securely to the lens bayonet lugs.
I can only assume that over time and use the filter lugs have become worn and have lost the spring tension required to fit securely to the lens.
Is there any way to re-tension the filter lugs, otherwise the filter is just way too loose on the lens to be usable and I will have to return it to the seller.
Regards
Kevin
Regards
Kevin
