GrahamPhotog
I just bought a Hasselblad - Nikon adapter so that I can start using my Zeiss lenses on my Nikons. I tried out my 100 f/3.5 and 500mm f/8 and all I can say is wow! The sharpness is amazing. My question concerns the fastest shutter speeds available. Since the Zeiss lenses have a fastest shutter speed of 1/500 second, can I override that when the lens is mounted on my Nikon D300 or F5 simply by going into manual mode?
I did check the EXIF data on a couple of pictures that I took, and it indicated a shutter speed on the 100mm lens of 1/1000 second. This would indicate to me that my Nikons can override the max shutter speed of 1/500. Can someone confirm that for me?
Also, if I am going to set the shutter speed on my Nikon using manual mode does it make any difference what shutter speed is indicated on the lens dial? Do I set the aperture still using the lens ring or can I adjust it on my D300 if I set the lens up as a non-CPU lens?
I am going to do my own testing, but I am headed up to Canada in a few days and may not have much spare time to figure out all the answers. I am betting that someone here has most if not all of the answers.
Someone on the Photo.net site has suggested that I need to use CF lenses and not C type in order for my Nikons to work properly in conjunction with the adapter. Can anyone comment on that before I go and buy any C lenses?
p.s. I just bought Ernest Wildi's fourth edition Hassleblad manual, and I will see if he discusses this issue there. It looks like a wonderful reference book.
