Hi Pal. While many of us V series "lovers" get sweaty, shake at the knees, and feel faint when anyone suggests an H series camera over a "true Hassy", I can understand your desires.
Having reached a point 5 years ago where I just "had" to move to an AF 135 format system from my Olympus OM system (with 8 sensational Olympus lenses), I can see where you are at. But, funnily enough I've never been truly tempted to do the same with my MF or rangefinder 135 format kits.
I don't own an H1; and originally I screamed when I learnt Hassy had "partnered" with Fuji to build some key body parts and the lenses, leaving behind the wonderful legacy of a long association with Carl Zeiss.
Why would Hasselblad risk traditional customers' defection by building its "next generation camera" with: some plastic parts; Japanese lenses; rectangular rather than square image etc.?
However, after experiencing the H1, I "woke up".
From my only experience with the H1 where I was leant one for a week and took one roll of film; I must agree with the majority of reviews (that I have read) that concluded the H1 is a truly wonderful camera in every respect and the leader in its class.
BUT, can I make 2 suggestions to answer your question?
1. Like the others have posted here - keep the V series gear! A perfect fully mechanical camera as a back up.
2. keep any V series lenses you have now since they can be used on the H1 with the recent adapter (so while you build an AF lens kit you've got others to use).
With regard to the H1, my observations from the little use I had are: The 80mm lens was excellent and produced very high quality images consistent with Fujinon's reputation in LF lenses.
The body was ergonomically well designed and quite intuitive to use. Despite the plastic shell, it's built around a robust stainless steel structure with a core of light alloy.
The film back is a clever design; the menu functions etc are good to use; the AF is the fastest in the MF game and very accurate with a wide EV range in which it works. The AF is well suported by continuous availability of MF without having to change the setting enabling you to adjust the focus point if necessary.
It has just about all the features available in the best AF 135 format cameras; so was the result of really good design, engineering and research in the beginning.
Many ask why the departure from 6x6 frames (me too!); but I think when you consider what's involved in AF lenses and a body that will do 1.5cm larger (vertical) frames, the result may be a horrible "clunker" with huge lenses and a huge body like a Mamiya 6x7 SLR (sorry if I offend anyone, but they are IMHO awful things to handle).
So maybe after some time for you to settle into the H1 and build a kit of lenses, then you might more safely liquidate your V series kit if it still gets too little use. This helps you to avoid serious regret if you later find that the H1 was not for you anyway.
I hope I've helped.
