Fisheye with CFV?
Hi
Is there anyway to get a full frame cover (180degree) fisheye with the CFV back? I'm thinking for example with adapters, other lens manufacturers than Hasselblad, etc?
I'm new in the medium format world, and don't know that much about lenses, etc.
Christian
The Hasselblad Zeiss 30mm fisheye lens has a 180 degree field of view diagonally. Not sure how this would translate with the 1.5 crop factor of the back.
503CWD, CFV, CFi 30/3.5, f=8, ASA 100, Lisbon Tejo Bridge
Regards
Lutz
  • EXIF
    LISBOA_P 0325sl.pdf
  • EXIF
    LISBOA_P 0325sl.pdf
Christian,
sure there is a way to calculate the angle, but not with my math skills
So I read the scale of my tripod using the marks on the focussing
screen
left/right up/down
about little bit more than 65 degrees and
diagonally upper left/lower down lower left/upper right about
little bit more than 95 degrees
At least an estimate.
Best regards
Lutz
  • EXIF
    LISBOA_P 0132sl.pdf
  • EXIF
    LISBOA_P 0132sl.pdf
...and...an excellent lens for portait as you see in the attached snapshot
from a young nice lady...
Lutz
Nice dog You got there, looks like a cross between a Rottweiler and a Doberman.
Looks like the cover-degree is around 120-130, which make it unfit for my purpose.
Thanks for the postings, appreciate it!
/christian
