I'm currently waiting for second version of the adapter to be manufactured with minor updates. I will wait for it to be ready to check if my drawing is correct and will publish it then.
Finally I can post drawing of adapter for CZJ Sonnar Zebra - http://www.wuala.com/mifki/Public/Hasselblad-Sonnar Zebra Adapter.pdf/
No changes to the lens required. I cut part of rear element of my test lens but later realized that it wasn't required at all. However part of inner ring (the one with holes) of my adapter must be cut away to mount it on the lens. It will be easily noticeable what to cut , it was just easier for me to do this manually than to measure and draw that's why it's not included in the drawing.
Now I will make an adapter for Zodiak-8 3.5/30 fisheye lens. Also I need to check if the same adapter will work for MC version of Sonnar and maybe make an adapter for Biometar 120mm. If you know of any lens that really worth mounting on Hasselblad (from any other system), let me know.
Pronvit,
Have you tried adapting the Arsat 55mmF.40 PCS or the Mamiya 645 50mm F4.0Shift lens? Better yet, the Schnieder-Kreuznach Angulon 55mmF4.5 PCS is the best of the shift lens out there. Just a bit harder to find.
I have a Hartblei 65mmF3.6 PCS and HAD a Hartblei in Mamiya-mount 645 65mm Tilt & Rotator that was never returned back to me by Hartblei.
A Tilit & Shift lens for the Hasselblad 2000/200 series body would be nice to have.
Look for the Mamiya 645 50mm Shift & the Mamiya 645 145mmSF.
Both lenses are available inexpensively. The 50mm Shift around $400-500 and the 145mm SF (Soft Focus) about $175 - 275.
645 isn't 6x6...
645 isn't 6x6...
