michaelhcothran
I just received a mint 40mm CF FLE that I bought a few days ago from Ebay. I need help with three items/issues -
1. There is a 93/40 ring screwed on the front. What is this for? It has no threads for accepting a filter.
2. I understand how the floating element works, but there are 3 click stops and 4 markings: infinity, 2m, 0.9m, and 0.5m. The 3 click stops do not line up with these distance markings. Can I set the floating element anywhere between the click stops, or do I need to use only the click stops. Then, do I focus and then set the floating element, and then refocus, or is there another procedure to this?
3. This one is the biggest issue I have - the lens came with a quick focusing knob mounted on the lens. I did not want it, so I took it off - only to discover that there is NO rubber gripping area on the focusing ring. I presume it was taken off before the focusing ring was attached, although I never would have thought that. I need to get a replacement rubber grip for it. Can anyone recommend somewhere in the US where I can purchase one?
Michael H. Cothran
Michael H. Cothran
