simonpg
Many of you helped me to decide upon the CF 60mm Distagon version of a 60mm to add to my kit between the CF 50mm FLE and CFE 80mm I have.
I still have not been able to find an "affordable" version in good order - still have not found a CF version full stop!
However, while away recently and using my 50mm a lot; I really wondered about the real added benefits I'd get from adding a 60mm. I did trial a C T* version just to be sure I liked the AOV which I certainly did.
So my question is of those with both 50mm and 60mm lenses. Where do you find the benefits in having and using both? Is the AOV too close to be of real benefit (I have been on the Zeiss site and used the AOV feature and they do seem very close)? Over time have you found the difference is only marginal, while the lens itself is obviously an excellent performer.
See, I see a lot of potential advantage in the 60mm where the 80mm is too "tight" and the 80mm DOF is too "limited". But is 60mm really just too close to 50mm, which FLE version I am very very happy with - a wonderful lens IMHO.
As a parallel ex&le I have the 120mm and 150mm and they sit between the 80mm and 180mm very nicely - each has its distinct benefits in my kit - none makes another "redundant" - apart from the obvious AOV differences, the 120mm offers added benefit of superb closer focusing; the 150mm has the added benefit of greater mobility when "out and about" over the 180mm (these benefits as an ex&le among others). So at the longer ends also having the 250mm and a 1.4xe I am totally satisfied and each is very much used.
I do see some advantage of the 60mm having half a stop speed advantage over the 50mm (a nominal but sometimes a real benefit); I also see some benefit in the 60mm being less sensitive to "user" created distortion at the edges when hand held (how sensitive that wide angle is to camera angle to subject); and maybe there is some weight/size advantage over the 50mm FLE. But, am I imaginging benefits that users with both may not actually realise (have come to fruition).
So, after that long story, your experience and opinions will be helpful to me. Thanks for your time.
